Hi all,
I have an application for Symbian versions prior to 9.1, which I'll need to
port soon.
The application has UID 3 = 0x06870724 (but it is not Symbian Signed).
I've read in the UIQ 3 docs that UIDs up to 0x7FFFFFFF are now considered
protected, and require signing, while UIDs 0xE0000000 and above are for test
purposes - but somewhere else I've seen mentioned the old test range,
0x01000000 to 0x0fffffff. I'm confused...
Anyway, the question is this: if my application is registered by Symbian as
0x06870724, can I continue using this UID or do I need to request a new one
from Symbian?
(Eventually we'll probably get it signed properly, but until then it seems
user capabilities would be enough)
TIA
Uriah
"Uriah" <[email protected]> wrote in message
news:[email protected]...
> Hi all,
> to port soon.
> test purposes - but somewhere else I've seen mentioned the old test range,
> as 0x06870724, can I continue using this UID or do I need to request a new
> one from Symbian?
You should turn this UID into an unprotected one by adding 0xf0000000 to it.
There's no need to register it again.
Sander van der Wal
www.mBrainSoftware.com
> TIA
> Uriah
That seems easy enough 😊 Thanks!
May I ask where this is documented? I sure couldn't find it in the UIQ 3 SDK
docs.
Regards,
Uriah
"Sander van der Wal" <[email protected]> wrote in message
> news:[email protected]...[color=green]
>> Hi all,
>> to port soon.
>> range, 0x01000000 to 0x0fffffff. I'm confused...
>> new one from Symbian?
> it. There's no need to register it again.
> Sander van der Wal
>> seems user capabilities would be enough)
>> TIA
>> Uriah
>[/color]
Seems like the link in the UIQ SDK is broken. Log in to the Symbian Signed
web site (www.symbiansigned.com) and, on the "My Symbian Signed" tab, select
UIDs on the left side menu, then the FAQ sub-menu.
Mark
Symbian Developer Network
SDK
> docs.
> Regards,
> Uriah
10x again! 😊
Uriah
"Mark Shackman" <-> wrote in message
> select
> Mark
> SDK
>> docs.
>> Regards,
>> Uriah
>[/color]
As Symbian Signed recently moved this very useful FAQ behind
registration, I created an open one with the info relevant for UIQ 3
development at http://developer.uiq.com/forum/entry.jspa?externalID=114
br -d
David Mery <[email protected]>, +44 7973 204 214
Editor - Developer program, Developer community team, UIQ Technology
10x a lot! It is indeed somewhat annoying that finding a clear FAQ requires
logging in to Symbian Signed whereas my application isn't signed yet and I'm
not sure it will be...
Uriah
"David Mery" <[email protected]> wrote in message
> As Symbian Signed recently moved this very useful FAQ behind registration,
> I created an open one with the info relevant for UIQ 3 development at
> br -d
