Hi frenz...
Does N95 support 802.11i wireless security protocol standards? i would like to use this phone in a wpa2 protected wireless network...
thanks in advance
--raj
Hi frenz...
thanks in advance
--raj
you probably found that already .. I'll repeat my post from another thread.
tools / settings / connection / access points / choose AP / WLAN security mode / 802.1x ..
go back then into WLAN security settings / wpa/wpa2 =
.. this is the part I leave to you guys .. since there are so many variations
This link might give you a hand getting your ssl stuff sorted ..
https://blogs.forum.nokia.com/view_entry.html?id=412
Let us know how you get on! 😊
I use mine with a Apple Extreme 802.11n Router, using WPA2 only security, works fine.
