n70 help
4 replies · 1,087 views · Started 05 February 2007
hi guyz
due to some virus ive formatted the mmc card i think its commwarrior
....now wen i m installing any softwares the s/w is being installed correctly
but i couldnt find the icon in my phone.....so pls help me wat
to do.......ive restored factory settings also....den also same
problem...ive installed ultra mp3...it was installed but i couldnt find the icon
in MY OWN folder......pls help me wat 2 do
Have you tried reformatting your phone?
Assuming you have made a backup first!
Then press *#7780# to reset.
Next step then is perhaps to re flash your phone using Nokia Software Updater. This is downloadable for free from Nokia.com.
This will reinstall the rom on your phone and possibly you will also update your firmware at the same time.
