N73 V 3.0649.0.0.31
7 replies · 2,457 views · Started 07 February 2007
If anyone has this firmware could they test if their mass storage option works upon plugging in the usb cable?
Thanks in advance:tongue:
I did'nt say that i think they've removed it,i'm saying that i think it wont go into mass storage mode because the Music Player is always running,as i get the message saying can t go into offline mode as memory card is in use by another application.
No problems here.
If it's definitely the music player, then just shut the phone down, restart and then try Mass Storage mode.
mr g wrote:I did'nt say that i think they've removed it,i'm saying that i think it wont go into mass storage mode because the Music Player is always running,as i get the message saying can t go into offline mode as memory card is in use by another application.
Hey guys, I also have this exact same problem. Mine is 73ME Thai version. No matter how I have done, it still showed that application use memory card. If you eject card, it said that no card present then this mode is imposible. I have to tried this because I want to delete themes manually, since they don't present in App Manager anymore and all are installed in phone memory. Even with newest firmware, problems are still in there.
delixis wrote:Hey guys, I also have this exact same problem. Mine is 73ME Thai version. No matter how I have done, it still showed that application use memory card. If you eject card, it said that no card present then this mode is imposible. I have to tried this because I want to delete themes manually, since they don't present in App Manager anymore and all are installed in phone memory. Even with newest firmware, problems are still in there.
The phone can still go to offline mode,so you can go to mass storage,by selecting offline in the profiles.
I try not to go down this route as i've had big problems with the N73 staying offline........so now i just tuse the card reader at the top of my pc!
i don't suppose this comes as any surprise, but just in case, i have just updated mine to v 3.0705.1.0.31 dated 26/01/07, with nokia updater, might be worth trying
voith
