delete mailbox
1 replies · 8,123 views · Started 07 February 2007
I set up my mailbox trying to use it, but it doesn't work so i want to delete it all together but cant figure out how. And the sending out symbol is on continually on. Is there a way to delete a mailbox and get rid of the symbol? i put the info in as was state din the owners manual, but it says nothing about deleting a mailbox.
Go to messages then- options- settings- E-mail - Mailboxes - then highlight the mailbox you want to delete and press options - delete..
Should do the trick..
