Callergroup madness on Nokia E50?
2 replies · 1,812 views · Started 09 February 2007
On earlier (non symbian) phone all new contacts were added to the default (and not removable) "unfiled" caller group.
Adding contacts to groups was easy: display "unfiled" and from that view add the contacts to their groups. Adding a contact to a group made it vanish from "unfiled".
Nokia E50: Arghhhh
There is NO "unfiled"group. I have to check EVERY (of my 300+) contacts with multiple keystrokes (joystick-pushes) and get out of that menu, enter another menu, search the contact again and add it to a group.
Madness.
Is there another way to do it that I am missing?
Is there any prgm that can do this better than the build in prgm?
I believe the e50 handles it through Team Suite. You can create your groups through team suite, add/delete members, call, sms, conf. call, e-mail, etc. I think team suite is better because it allows you to select all or part of the group/team you create for any action you want to do.
But then again, your needs may vary.
sandeep108 wrote:I believe the e50 handles it through Team Suite. You can create your groups through team suite, add/delete members, call, sms, conf. call, e-mail, etc. I think team suite is better because it allows you to select all or part of the group/team you create for any action you want to do.
Thanks for your answers, but with teams: same problem. No view of contacts not belonging to any group (or team in this case).
