Telexy Networks Inc � SymSMB for S60 v3 seamless networking with E60, E61 or E70
5 replies · 11,535 views · Started 09 February 2007
[INDENT]
  • Are you tired of having to constantly plug your phone into PC using cables to manage the files on it?
  • Are you worried that you can miss an important call while plugged in?
  • Do you dislike not being able to listen to your favourite tunes or to watch
    cool videos while connected via cable?
[/INDENT]
If you answer �yes� to any of the above, you definitely need SymSMB 1.10!
SymSMB 1.10 provides instant access to any files on your Symbian S60 3rd edition phone from any computer on the network without cables and any special PC software over WiFi (WLAN). This product allows sharing any drive or folder on S60 phone and accessing this share from any computer on the network. SymSMB 1.10 is based on Telexy Networks implementation of SMB/CIFS/NetBIOS protocols for Symbian S60 3rd edition.
Some very obvious use cases:
[INDENT]
[LIST=1]
[*] Copy pictures from the phone to home PC.
[*] Sync audio(/any) files between PC and phone.
[*] etc.
[/LIST]
[/INDENT]
You can find more info about and download SymSMB 1.10 on the official site of Telexy Networks Inc.
Does the computer have to be joined to a domain in order for this to work? Does it work with workgroups as well?
BlackN91 wrote:Yes, it does work with workgroups as well.
I can't get it to work. Could you tell me how to set this app to work whith workgroup? Where can i enter workgroup name?
Thanks in advance.
