nokia n80 connections
3 replies · 2,245 views · Started 09 February 2007
ive not long purchased a nokia n80 and sort of new to wireless.
can anyone give me any ideas on what sort of wireless setup to buy.
i need a pc to be able to connect ot it as well, and cable broadband.
i live in the uk.
anyone got any ideas of what wifi product ot buy to make it as easy as possible to connect the pc and nokia n80 to wireless
thanks in advance
Any regular Wi-Fi/WLAN access point/router should do (Netgear, Linksys, D-Link, A-Link, 3Com,...).
Look specifically for "802.11g" support (but safest to get one that also supports "802.11b", at least).
yes, buy any gateway device (router + modem) with Wireless lan capability and RJ45(ethernet) ports. then you dont need a pc. if you buy a pc you can connect it to network either through wireless or through RJ45
well the only problem is i have x64 bit windows system, if i buy a standard router and connect through pc as an rj45, will this still work, even without the dirvers, i dont really need a wireless network to the pc, just for other things around the house
thanks
