Guys is it safe to remove the folders under E:\Sys\Uninstall? using N73.
E\Sys\Uninstall
Probably not, and why would you want to ??
free some space!
saad3000 wrote:free some space!
Get a memory card/bigger memory card 😉
That's like deleting Windows off your PC to free up some space on your HD !! LMAO 🙄 :laugh:
yah right!!!
It isn't like removing windows from a PC - very bad analogy. Removing the uninstall folder entries (which aren't normally that big anyway) is more like removing the $Uninstall$1234 folders within \Windows on a PC.
In general it should be safe, but in future to remove programs, you will have to do it the painful manual method.
Jeez, lighten up ! It was a tongue in cheek comment, hence the smilies.
