6630 Menu Key Not Working
2 replies · 4,684 views · Started 10 February 2007
Hi - The menu key has stopped working on my 6630...
When it's pressed, the screen looks as if it's going to show the menu but then returns to normal phone mode instantly. When you hold the menu key down, the list of running apps shows up but I just cannot access the main menu....
Any ideas, ?? I've removed all cards and battery for over a day but no luck. I cannot perform a master reset or anything because I cannot access the menu....
Firmware is 6.03.40 29-09-06 RM1
Many thanks
