my 6681 cannot install apps to my mmc. why ?
2 replies · 3,619 views · Started 12 February 2007
my 6681 cannot install apps to my mmc. why ? i used kingston mmc mobile dual voltage 512mb. if i install my apps to my mmc. there are no files but there are folders. so if i install profimail, in folder apps folder there is 1 folder named "profimail", but in that folder there are no files ? and if i install the program to my phone memory. its no problem.
and while i capture a photo or a video. its captured by my camera but i checked at my gallery. the file is corrupted.
maybe i can get the conclusion, my mmc is cannot store file from my 6681. but if i copy files from pc, no problem. whats wrong with my phone ?
so can anyone help me ? thx and sorry for my bad english ^^
No idea whether the problem is because of the phone or some incompatibility of the card with the phone. Do you have another memory card to try to see if it behaves differently?
You can also update your phone to latest firmware in case the problem is there:
http://www.nokia.com/softwareupdate
i have not encountered such problem except for applicaton incompatibility.
yeah, i go for whawt N/A said... try other mmc. if the other mmc works just fine then i might conclude that your mmc might be defective...
