Four gig card in the E61?
4 replies · 5,073 views · Started 12 February 2007
Has anybody tried to run a four (4) gigabyte memory card in the E61... will it support them?
(I couldn't find this topic on a search of the forum, so apologies if it's dealt with elsewhere.)
:con?
Thanks nj7, I found the reference on the mobymemory site,
"Get extra memory capacity for your push-mail Nokia business wonder and blackberry-beater. Want mobile GPS maps? Like to take some music on your next business trip? Then E61 with extra memory (up to massive 4GB miniSD cards) is for you."
But then if you scroll down to the second 4 gig card it says
" Mobile Compatibility List:Not for Nokia N73, N93, E61 "
http://www.mobymemory.com/E61-Memory-Cards.asp
Maybe it works with some 4 gig cards and not others... perhaps I'll have to make a guinea-pig of my phone and find out first hand.
looks like there may be barriers with moving up to 4 gig, found this:
http://forums.mobymemory.com/shwmessage.aspx?forumid=93&messageid=5333
and this
"SanDisk announced it in september but its not available quite yet..and even if it was it will NOT work on most devices that take miniSD including the Nokia E61 unfortunately... because SDHC works differently than your regular SD cards..4GB SDHC cards will only work with SDHC compatible devices .. so unless Nokia comes out with a firmware update that will make SDHC work on the phone we are maxed out at 2GB....for more info on SDHC http://www.sandisk.com/sdhc/SDHC.pdf "
above quote found at http://samgonzales.blogspot.com/2006/10/4gb-minisd-on-nokia-e61.html
quanta wrote:Thanks nj7, I found the reference on the mobymemory site,
Ask them about the different statement on their site!:frown:
