Is there a shortcut that closes all running programs even though you don't see them?
How to close programs
Happycamper wrote:Is there a shortcut that closes all running programs even though you don't see them?
If you hold down the menu button, you will see s list of programs that are open, you can then select that program with the D-pad and press "c" to close that program.
Contacts is particularly notorious for staying open...
Hope this helps,
BHLC
