Perhaps there are E61 joysticks which are stiffer than mine or something. I have one of the first units from Finland (English/Spanish keyboard, by very happy coincidence and luck). Though a friend recently got one of the infamous 3 branded units from Hong Kong, which I believe has the same feel, so I doubt the variation theory.
I am not an expert touch typist, preferring to hold a given device in both hands and type with my thumbs primarily. For me, the 5mx and Mako keyboards have inconsistent feel between different keys and require too much pressure, and they are intolerant (especially the 5mx) of being pressed from any angle other than directly above (difficult while walking around holding the device; though I can see how they would be better for a touch typist, using them on a table). The 3c has none of these problems, and is my favorite for portable text entry, it just has too many other limitations these days to be a primary PDA. I have typed emails on a 3c which pressed its limit of a 50 KB text file in one shot, and that is pure text, with no formatting codes! I have done similar writing with the E61, and find it to be the next best for me. I'm not likely to win any speed competitions, but I can type very large messages comfortably, sometimes spanning hours.
I stand by what I said about the joystick. Perhaps I have not yet had the pleasure of using a device sporting one of these mystical, utopian D-pads. Every other pointing device on a PDA or phone which I have used is less pleasant to me (including the directional pad on the Zaurus 5500, those on various iPaqs and Jornadas, the joystick on the 6800, which would be better if it could be pressed, the ball on the Blackberry Pearl, etc.).
The E61 joystick is very positive in its response and feel. It definitely and consistently goes the direction I want it to, and not any other, unlike many other devices. It reliably allows me to press it in to select items, without simultaneously or alternatively deciding to add a directional component to my selection by itself, unlike many others. And it does it in a way which does not require me to move my thumb all around in the process, like some others (Zaurus 5500 for example). And all of this while also allowing excellent one-handed use (though I do have two functional hands, thanks for asking!).
I would be curious to hear suggestions of devices which have what would be considered to be good D-pads, especially ones which are regarded as being better than the E61 joystick. Maybe I am missing something. I typically try to find the best of whatever it is I am looking for, which is why I ordered a $500 cell phone which isn't even marketed on this continent, rather than buying what was offered to me by the local carriers. And for me, the E61 is still the best of the best, bar none!
Also, I ***LIKE*** the Pop-Port! So there! 😉 The thing has IR (thank goodness! IR is still extremely useful!), BT, and Wi-Fi...I really don't see why everyone makes such a big deal about the perceived lack of 'standard' USB connectors. The extremely robust (and nearly ubiquitous) Nokia charging jack (hopefully the new mini version will prove to be as robust; I swap batteries with an external charger to prevent undue wear on the jack anyway) is much more desirable to me.
