HowTo Rename Application on N73?
5 replies · 11,002 views · Started 12 February 2007
Guys We all know by now how to make Sub-folders on N73 or other devices, but the thing is that I TRIED all tricks just to rename and non-worked!! I have N73ME anyway to Rename Apps?
EASY like the subfolder.Anyhow what you do is the following:
Goto the menu and place your desired Application you want to rename it in your 1st line of your MENU in the UPPER-LEFT position .Stand on any Folder in the menu and choose OPTIONS... PRESS THE TURN OFF button ONCE so that you can choose OFFLINE profile this will refresh the MENU and the RENAME will be on the 1st application u want to name it 😊))
That's amazing!
I've always wanted to rename the web/services icons to something more memorable (not that I use them that often...).
Cheers!
Wow, thanks. I thought i'd have to play around wit jad files on the pc but this is so simple
Damn, thought i'd be able to install another copy of the same app, no success 😞
Hi
Trick to renaming an application is very good.
Can you please tell me How to change icon of installed application on Nokia N73.
and if possible how can we hide an installed application from get it displayed by anybody exploring the mobile.
