Mail for exchange
9 replies · 4,467 views · Started 12 February 2007
I just upgraded my firmware to v4. And I also installed "Mail for exchange" 1.5. But this wont work. What should I do? Anyone else who had this problems?
//Lobben
homers wrote:Hi,
//Lobben
Welcome..
We'll need a little more information to help you.
How are you using Mail for exchange?
With your own Exchange Server or a 3rd Party service?
How is the application configured? (don't post genuine emails / passwords though 😊 )
What do you mean by "this won't work"?
Does the application not open? Does it return an error - if so, what is the error? Does the sync fail ? If so, what is the error?
Mail for Exchange 1.5 was written ONLY for E series and will not work for N series. RTFM the readme that came with it and it has it in BOLD letters that it will only work on the E series.
TazUk wrote:Welcome..
I'm using Mail for exchange for syncing my E-mail, contacts, to-do and so forth with our Exchange server sp2.
When I try to start Mail for exchange it says; Unit not supported. Unit doesn't support this version of Mail for exchange. (Translated)
homers wrote:I'm using Mail for exchange for syncing my E-mail, contacts, to-do and so forth with our Exchange server sp2.
I think you really have problems understanding.. this version will NOT work on the N80..
You will need version 1.3.1 as this was the last working version for Nokia N80
bchliu wrote:Mail for Exchange 1.5 was written ONLY for E series and will not work for N series. RTFM the readme that came with it and it has it in BOLD letters that it will only work on the E series.
OK, I only read the install guide. My bad. But dont be arrogant!!!
Help me instead.
bchliu wrote:I think you really have problems understanding.. this version will NOT work on the N80..
I read the post erlier and posted later... didn't read your post before....
homers wrote:OK, I only read the install guide. My bad. But dont be arrogant!!!
Help me instead.
I'm not.. and I will help you.
1.3.1 is not available to download anymore from Nokia. You will need to get it some other way.
Took the liberty to "HELP" you on this and uploaded the copy I had to Rapidshare:
hxxp://rapidshare.com/files/16154725/MailForExchange_1.3.1_.SISX.html
This should fix your issue. (copy above and replace hxxp with http).
bchliu wrote:I'm not.. and I will help you.
Thanks, I will try this out. After my meeting...
Hey Hey Hey
It worked out fine. Tanks.
