Ok, after a discussion in another thread I have managed to get hold of the 660 build 1223 map for UK and WE, but my current map is just a Great Britain one.
What file do I need to transfer to the new folder to keep my favourites, I can't re-enter them all as some are GPS locations rather than addresses and some I don not know the addresses.
Thanks for any help
Moving Favourites in TomTom
I believe the file is the .cfg file (there is only one).
Mike
Thanks for the suggestion, but I have just tried it and it does not work.:con?
Check that the .cfg files names match.
On my previous install (Benelux), the file was called MapSettings.cfg, Now it is called Western-Europe.660.1233.cfg
Also, try copying traffic.inc
I added a favourite to TomTom and these were the only files that changed.
Mike
I had renamed the config file to a similar form from where it came, but Tomtom didn't see it. So instead I created a new home and looked at the file it created and renamed my file to that, which was a shorted version of the name I had chosen.
Thanks foryour help.
Maybe I spoke too soon, it seems that not all of the favourites are there, I had to reset my home place and one I set the day before was not in there.
