N73 is getting hunged when taking pictures or using any applications, only power button works.
If i click menu, it will appear after long time, same if I try to access any application, it responds very late.
Formated 2GB memory card, it didnt help me.
Re-installed the firmware... no luck.
If I restart(power-off and power on) the mobile Works fine for 5 mins... same problem again.
Anybody has any clue.. Do I need to take to Nokia care center ?
THanks in advance...
