Two questions about N93:
Is there anyway of changing the program that loads when you hold down the 0 key. I want it to load the Web program from the Internet folder but it loads the Services program. And maybe if I ever get round to downloading the Opera software I would want it to load that up instead.
I know you can set a default access point but I'd rather have it try to access using one of my wifi access points and then just use Vodafone Live if none are available. It doesn't seem that complicated, even making it switch if I move out of range of one of my access points wouldn't be difficult but is it possible? It's just that if I search for a local access point and none are available I have to go back to restart the program or otherwise prompt the access point menu to reappear which is tedious if I just want to have a quick glance at the headlines.
