hi guys,
i need a software to record the Fm playing on my n70 and also need a software to set multiple alarms. i have alarm manager but its not working for me, i also have handy alarm but its a trial version.
thanks in advance.
hi guys,
thanks in advance.
As far as I know, you cannot record from the radio. If you have v5.xxxx firmware, you will not be able to set multiple alarms, this being one of the worst v5 firmware's bugs. The only alarm from Alarm Manager which it will work is the first one, because that's the only one which deals with the clock and not with the calendar. I guess you'll need to wake up at the first alarm 😉
ok no probs. thanks for your efforts man.
Drop Igor (author of Alarm Manager) a mail.
I had the same problem with AM after a firmware upgrade on my N70.
Igor mailed me a fix for the problem.
It's not perfect but I do get all 8 alarms working.
This was some time back. He may have a decent, fully funtional fix by now.
Cheers
