I mostly use a bluetooth connection between my phone and PC.
Since carkits are available that utilise BT for connection is there any way that I can use my PC to make calls using the phone across the bluetooth connection ?
If you find Bluetooth software for the PC that implements the correct Bluetooth profiles, then yes. I don't know of such Bluetooth software.
Thanks for that. Going by yr post count I guess if you don't know about it, it probably doesn't exist
Seems something that should be easy to do. PC software should be able to replicate the required functions.
Just a matter of someone creating the req'd app.
Cheers
