I have recently installed eMessaging (latest version) and also ActiveDesk 1.50a at the same time and am having problems with messaging. I have my messages stored on the MMC but every couple of hours or so my 9210 reverts back to using the "Communicator" internal memory as the message store. This really screws things up and when a message arrives it won't stop the "message in" tone. I also get an error when trying to message out after this has happened until I reset the machine again. It's driving me nuts!
I don't know whether any of the freshly installed progs has caused this or whether it could be down to something else. I'm using 3.62.
Anybody any advice or having similar problems?
Messaging Problems
I am assuming that you have tried removing ActiveDesk and eMessaging and still have the same problem?
I had the same problem with 3.54 and 3.62.
That was even b4 i installed eMes or AD on the 9210.
Some1 else i know still has the problem 3.18 and has only the standard software installed!
Since 4.13 i have not had the problem anymore.
I think it could be a bug in the actual firmware, not some installed software.
I have removed eMesaging and left it for today. Same thing happened again but only once today.
I'll try removing Active Deask but somehow I don't think that's at fault.
I feel a complete format coming on which may not be a bad thing 'cos I'm sure my 9210 is choked up with loads of unwanted files from failed installations and program removals.
