Reminder Application with a Difference....
0 replies · 2,188 views · Started 20 December 2002
People have been asking for an alarm system that allows customised alarm sounds. Does Ximplify deliver this? No, that's not enough, too easy..... Ximplify decided to set their own challenges and deliver more than just pretty noises.......
You can set alarms and reminders with customised alarms and graphics. You can tell it to 'Remind me in ten minutes", "Remind me every hour" and "Remind me on....".
You can define 16 often used alarms and reminders.
The only limitation, as far as I can see, is that it does not integrate with the Calendar, but I wouldn't put it past Ximplify to find a way around this
It costs $12, but for a limited time only, you can get your paws on this for $8.40, now how cool is that!?
Get it here and support your favourite Symbian web site! 😊
