I want to copy a file from my pc to the phone but I don't know how...
it's a .rsc file...
Please can someone help me?!? 😮ops:
New user searching for an answer
Do you have Bluetooth or IR ?? If not send it via eMail, if you have that set up.
Please try to be more specific in your next question. :-?
And try Search on upper right corner of page. It usually helps.
Ok...
My problem is that I want to move a file from my pc through IR to my phone... it's a .rcs file and I want to replace the old file with the one I have...
Oh! And I don't have an e-mail account in my phone...
[7650] menu>connect.>Infrared
Allign the two devices [7650 + PC iR port]
PC should reconise the phone and give it about 30 seconds to ready itself and install neccersary files
Then on your desktop you should have a new icon saying 'Send Files to Another Computer' Click that and browse to find the file you want to send, select it and press the magic SEND button!
Then use SeleQ to find the new file in the mailbox, cut [or copy] it, find the dir of the one u wanna replace and paste it in, select yes on any boxes stating old file will be replaced etc...
