N73 Microphone?
1 replies · 6,296 views · Started 16 February 2007
Hi everyone,
Ive been a visitor to these forums for a while now, however I have registered today, due to the fact I have a problem, and would really appreciate some help!
Firstly, I own a Nokia N73. Been pretty happy with the phone thus far, however I recently purchased a new all black chasis for the phone, as I think much more of it than the standard silver. The chasis came with no instructions (was an ebay job), so after googling for a while, i found this site with some nice photos on how to strip the phone.
www dot adam.com.au/.../*Nokia%20N73%20Housing%20Removal.htm
The guide although useful, did not contain info on how to remove *everything*, and thus, my problem. I have removed everything I can see, and placed in the new housing. The only problem? My mic won't function now.
Im not totally sure where this is in the housing, but I believe it to be a small round rubber thing with 2 pins coming out of it that connects to the mainboard. I accidently dropped these pins during extraction and lost them. Is there anything I can do to get the handset functioning again?
Any help at all would be much appreciated!
Cheers,
Tom
hi,tom the microphone is the small round rubber with to metal prongs if you have broke these off then you will need a new one and you must put it back exactly the way it came out.it should go in with the 2 prongs to the right of the phone.you can buy a new one for under a fiver just go to shop.com uk and enter nokia n73 microphone into search cost �1.49 +�2.95 total cost �4.44 hope this helps cheers liz.:tongue:
