Hi, can anybody please give a step by step guide, to a newbi, on where & how you get the album covers to show along side the albums. ie where do you get the covers from & pair them to the correct album.
Thanks.
How to get album art on a N73 ME?
Find the images (use Google), then copy to your Images folder on the N73 (or wherever you like, so long as you know where to find them).
Then, in Music Player, got to your list of albums and highlight the album you wish to add cover art to. Choose options, then album art, then options, then change. The phone then navigates to the image gallery and you can choose the artwork from there. Once the process has completed you can delete the image from the phone as the thumbnail is now stored in the tracks ID Tag 😊
Get the software Tag & Rename.
U can edit all song information... and luckily the new firmware has started to show images that are tagged by Tag and Rename..
Yipeeeeeee 😉 😉 😉
Excellent finally!
I'll try Tag & Rename. So album tagging with iTunes or MediaMonkey does not work with N73?
Do you also know if a song tagged with album album art keeps the picture after converting to M4A in Nokia Music Manager? Or does this only work with MP3 files...
karthikeyan10 wrote:Get the software Tag & Rename.U can edit all song information... and luckily the new firmware has started to show images that are tagged by Tag and Rename..
Yipeeeeeee 😉 😉 😉
I'm on the latest ME firmware, and have gone through using Tag & Rename on all the files .... it doesn't work .... at least not on WMAs. Maybe it works on MP3s only?
