does anybody knows why the p800 is not visible by iSync and little BT finder menu using 10.2.3? I had problems also reconnectind the BT handsfree HBH-30. Now it's no longer pairable with the phone... :x
Mac and P800 bluetooth sync
iSync will not work with the P800 yet. To pair reset your P800 and your mac. Then Pair. You can use Bluetooth File Exchange in the utilites folder.
Matthew Hart
Florida
[quote="matt5115"]iSync will not work with the P800 yet. To pair reset your P800 and your mac. Then Pair. You can use Bluetooth File Exchange in the utilites folder.
Matthew Hart
Florida[/quote]
Ok. yesterday night i solved the problem...anyway thank you so much! i found the app "BT file exchange", but how it works? can i find something somewhere about it? thank you.
To use BT File Exchange - set the P800 to discoverable then drag an item on the file exchange icon, then click search it will find the P800 then click send.
Matthew Hart
Florida
