all_nokia_910_data.sis Installation
1 replies · 2,259 views · Started 26 September 2001
A question
Does anyone know if when installing the
all_nokia_9210_data.sis file you
get to choose which applications to install and on which
drive?
Thanks for your help..
Andrea
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote</font><HR></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
On 2001-09-26 1215, andrear wrote
A question
drive?
Andrea
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
It only asks which drive it install. There is cd in sales pack where is "all_nokia..." sis file and there is also every application it's own sis file.
Or you can install "all_nokia...." and then remove applications you want from "add/remove" in control panel.
Regards
JeP<font size=-1>[ This Message was edited by JeP on 2001-09-26 1257 ]</font>
