I've installed spruce blocks and i cant find it anywhere and i cant uninstall it
Please Help :cry:
Please Help :cry:
So it is not in Apps then?
Could you be a bit more specific in your description of the problem 😃
Perhaps its not installed... Try looking in c\system\midp\spruce technologies ... see if its actually installed... then check your message inbox, You DO realise once u send it to your phone u THEN have to install it... then u can delete message... Please post more
SeleQ is a good file explorer.. try that
