Announced over in our forums was that emoze, the popular (for those on flat rate data plans) push email/contacts/calendar system, has just been upgraded to work on S60 3rd Edition devices like the Nokia E61 and N73.
Does not work properly on N73. Only works for a few seconds before it does nothing. Constantly need to reboot the phone to pick up mails. To make matters worse the mails are delivered into a subfolder of the SMS container.
Conatcted support about it but they suddenly stopped responding after they got bored of my issues.
Tried everything from flashing the phone with latest firmware and resetting the phone multiple times.
You may have installed emoze using POP3, You need to connect your N73 using PC Suite, Use the emoze wizard to identify the device. This will install the Mobile client on your device. emoze works wonderfully on the N73...
No I did not. I've tried everything and it's still no good.
I have tried to set emoze up on my nokia device and keep getting file format unknown not supported errors- my phone does not support .sis files. anyway of fixing this? Is there a java verson I can download?
ill be back 2 check response.
I love emoze, but they have to put the email's in the email folder. a subolder in the text inbox is really weird
