This may be a really dumb question but i'm going to ask it anyway ... is there any way to tell what bluetooth devices are connected to the n80 ??
Regards,
Simon
Regards,
Simon
I dont think you can see whos attached to you via BT, but you can see who is paired with you.
I guess if you cut a piece of string to a length of 10m, then anyone within that length with a BT device could be connected... anyone outside of it probably not! 😉
Thanks :redface: I was hoping to see if some of my bluetooth devices were actually connecting but have now found they aren't even though they pair as they rely on A2DP profiles.
