TipicME Question!
7 replies · 1,457 views · Started 21 December 2002
Im using the bluetooth connection Via PC thing and manage to connect etc.. Hoever... When I select yahoo then continue It says 'waiting server response...' Is this a problem on my end [7650 or PC], Tipics end or Yahoo? I also tried MSN and that returns the same response [or lack off!] Any ideas!?
Then it pops up after awhile saying '502Internal Timeout'
I am using Tipic via GPRS and it stays online most of the time.
However I realise that Tipic does not operates at certain hours.
By the way, could you explain how you use Tipic using Bluetooth?
[quote="Theran"]Hi,
By the way, could you explain how you use Tipic using Bluetooth?[/quote]
Yep!
Firstly connect to your phone via bluetooth serial port, then allow mRouter to connect ... then use creat new GPRS profile... everything standerd like no password... IP 0.0.0.0 etc.... then connect via that - works a dream
im usin win XP and 1.2.2.9
There are sometimes troubles with Tipic's connections.
And it starts to connect only when it get to 80% before that it does
something that i dont know 😃
Just try again, it should work. Have not tried via BT -> PC though.
Well i've been using Tipic>BT>PC connection lastnight and quite alot too! Worked fine... I tryed the desktop client and that returns same error... so it must be a server problem
[quote="Zipper"]Im using the bluetooth connection Via PC thing and manage to connect etc.. Hoever... When I select yahoo then continue It says 'waiting server response...' Is this a problem on my end [7650 or PC], Tipics end or Yahoo? I also tried MSN and that returns the same response [or lack off!] Any ideas!?
Then it pops up after awhile saying '502Internal Timeout'[/quote]
This is because the Tipic server is in Beta testing stage. They have clearly mentioned it on their site that, because this, the service may not be available occasionally.
Its a real pain though. I'm also disappointed with the rather funny interface.
PS: This have been topics on Tipic. You could have posted this question in that thread
