E50 battery Poll
3 replies · 2,042 views · Started 20 February 2007
I have a Black E50 with a Bl5C battery, and with an averge of 20 min talktime per day it lasts a max 3 day with minimal useage.
How is yours .... is Bl6C much mor different?
b0gy wrote:I have a Black E50 with a Bl5C battery, and with an averge of 20 min talktime per day it lasts a max 3 day with minimal useage.
That run time estimate is correct - that is about what I get if I dont put my E50 in offline mode when I am sleeping. But if I do put it offline when I am asleep, then I can get a bit almost 4 days on that BL-5C.
The BL-6C batttery adds about another day to this total. BL-6C only 15-20% bigger (1100mah vs 950mah) than BL-5C, so you cant expect it to dramatically change your life!
That said the BL-5Cis very small. There is nothing stopping you from buying etra battery+charger and then just carge up the extra batter and take it with you if you go on a long trip.
I forgot to mention that those numbers are with the screen at standard brightness. If you are willing to me more aggresive on the screen brightness settings you can get more battery life. Key is to get a simple theme with good contrast.
