Messages in folders
3 replies · 1,663 views · Started 20 February 2007
I have an e61 and have loads of messages in folders.
I need to get them on my PC as the text messages in one folder are to be evidence in a Court hearing and I need to print them off, or put them in a word document.
Whats thew easiest way to do this as the only way I can see is to move them back to the inbox and get them from 'messages' in pc suite?
Not what you are looking for, but worst case scenario you can move all in your inbox into a new folder (perhaps called temp) which empties your inbox. then move the required messages into the inbox, use pc suite, then revert your folders back to the original setup. The "Mark All" option is your friend here.
cheers for the reply, that seems the only way i can see, you would think either the phone browser or messages app would allow you to organise messages!
Well I am surprised it doesn't like the subfolders, but I suppose thats a good feature request for the next service packs if it isn't already there.
The method above isn't ideal - but it shouldn't be too much of a burden assuming all goes well. I would just count (if you can) the messages in your folders first so you know if you have lost / misplaced any.
