I was using pc suite to back up my text messages, then one day it wont find my messages through the computer. It says that its been disabled. Ive uninstalled and reinstalled the program on the computer. Is it a computer problem or a phone problem. Thanks
PC Suite Problem
think we're gonna give this a bump.
well, has it been disabled??
Theres options in PC Suite... make sure you have the right version of PC Suite too for the N80...
try to search your computer for the message files or something
kontraband. yea i think its disabled. where are the options to get it working again. What do i do. Thanks
when your phone connects via BT, before it syncs you can change the settings and what you do/dont want to sync... You may have a setting missing in there ?
(from memory, I havent looked)
