Well, after my 2gb Transcend 80x card didn't work at all with my N80ie
(http://www.allaboutsymbian.com/forum//forum/thread/56216/)
I have decided to buy another card to replace it.
I found an A-Data 2gb card for $22 on TigerDirect, would this card work fine with my N80 without giving me errors or a corrupted database like the transcend one did?
(http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2549383&CatId=1601)
Thanks.
I have the A-Data 2GB on my N80ie. It's been working fine so far.
Other than it's slower than my orig. 512MB from Nokia, the only quirk that I have is...everytime I use it w/ Smart2go...the apps. always hang on exit.
Thanks, how much slower is it though?
SilentEcho13 wrote:Thanks, how much slower is it though?
not very much IMO. You can feel it when installing softwares / themes on it. I used the memory card reader last time to put mp3s and videos on it and it was decent speed. Playback is also good, I never get lag or anything like that...smooth playback for video and mp3.
HTH
