Hi guys.
I have been lurking around from quite some time and have finally decided to register and post.
I have a problem using NSS. I simply cannot get it to read my phone (Nokia 6288). I also have an old 6230 and that works with NSS no problem.
I keep getting an error. The error is displayed in the lower left corner and says " Scan for product�.Error!"
Also, when I initially connect the phone and press "scan for new device" the "device info" page displays that�s everything is found except the last item - ->Products Dir('products'😉.......Not Found.
I am using the latest available version of NSS and have already tried uninstalling all Nokia software and drivers and reinstalling it all again.
Any advice/thoughts/ideas are much appreciated. Thank you all.
hummm sounds the same as my problem im having
today i decided to find a way round the sim lock for my 6280 by changing the product code to another (cant member which 6288 IIRC) well first time i scanned for fone it found it no problems at all.. so i entered the code and flashed it again no problem..
now went to the NSU to update it but it says it's un-reconized so i thought i would give another code a try.. now when i scan, try to flash ect the message i get is
NSS: Checking Diamond...Not found.
or
other errors
basically it doesnt see the phone anymore 😡 but the phone is working same as it was just NSS is playing up, i have uninstalled and reinstalled everything more than once
any ideas people google has revealed nothing 😡 :icon13:
thanks!!
Hi!
with the new version is all ok!
Nemesis Service Suite Beta 1.0.38.12
NSS103811.exe
:icon14:
