I wonder if anyone can advise whether the E61 has a built in GPS unit, or whether an additional unit needs to be purchased? Also, which software can be used.
Thanks,
Saul
Thanks,
Saul
No. Is necessary purchase an external antenna.
yes you need an external gps reciever, normally bluetooth. If you buy tomtom6 it is an option.
If you want just maps then check out this http://www.smart2go.com/en/index_html
