hi!i have a question about keylock on M600. what dose it lock...only keys or keys and screen?for ex. if you have keylock on and your m600 in your pocket is there posibility of turning functins on by excedently touching the screen? thenks
m600 keylock pls help
keylock locks the screen and the keys. if the screen is tapped, the unlock message appears. you could use up your battery charge fairly quickly so i suggest you get a phone case.
It's smart enough to only half-light the screen when it shows the "keys locked" message though, so I wouldn't worry too much. Never been a problem for me.
A screen protector is a good idea though, just in case - the touch sensitive screen is soft, so it'll pick up scratches from anything else in your pocket VERY easily.
thenks!!it halped me alot 😊
