What heppean to the phone if you failed installing IE? Will the phone brick or something
If you dont like the IE can you uninstall it
Greeting's
There is no way to downgrade from N80ie to N80 if you dont like it. Yes there are a million chances of the phone not working at all if you make a mistake and Nokia will not repair the phone since you tried to FLASH the phone something that voids the warranty.
bytewrangler wrote:Greeting'sThere is no way to downgrade from N80ie to N80 if you dont like it. Yes there are a million chances of the phone not working at all if you make a mistake and Nokia will not repair the phone since you tried to FLASH the phone something that voids the warranty.
I believe it is possible to go back to an earlier firmware version now, many bricked phones are also bought back to life by continuing to re-flash with phoenix several times, most important thing is when you start the flashing just leave the phone alone for a good 30 mins and don't touch or knock because the usb cable is sh*t, and I believe this is the main cause of failure.
Nokia will repair the phone, but will charge you for it
