file explorer
3 replies · 2,274 views · Started 22 February 2007
Hi guys 😊
is there any software through which i can see all the folders of the mobile on my computer? if we connect through PC Suite, i cannot see the system folder and other files, so im unable to copy "mails" folder or any other similar things thats y i m asking for this.
i mean just like we can do things in FExplorer or seleq, similar software for PC.
i hope u understand what i wanna ask for :con?
No, because that ones can�t be connect by USM mass storage like new ones. But you can see on phone with FExplorer from gosymbian.com or remove the card and use a card reader.
The only thing I can remember to do this was a plugin for Total Commander, but I was never able to make it work. You can do something else, though. Copy the files which you need somewhere on the MMC or phone where they can be seen by PC Suite. You could also buy a card reader.
