MSI BLuetooth Compatibility?
5 replies · 2,006 views · Started 21 December 2002
Hi there!
Heres my qustion:
Im planing on buying a bluetooth adapter for my pc (motherboard ASUS) and i have read here on the forum that most people uses MSI Adapter but i dont know if i can use this with my PC??
If not please give me alternatives that dont cost too much money!
Thanks a lot !
The MSI Transceiving Key should work with most USB enabled motherboards because its an USB Bluetooth Adapter/Dongle.
So if your motherboard is USB enabled (Most motherboards are USB enabled these days) run to the store.
I'm waiting for one myself.
Hi, I'm Using the MSI USB Bluetooth Adaptor and works fine. Only dificults with the software because when I try to print from ms aplications it gives some errors. I dont have check it , but seems could be solved with configuration. I have and PIV with Asus P4B533 Board.
