hi all, is it possible to use another way to increase volume of the music player or the fm radio, without using volumekeys of N73?
because this buttons aren't wxorking for me!! is there any way to do that??????😡
increase volume without using volumekey?
any help plz!
Why would there be with dedicated volume keys ?! Get them fixed !
The only other way to do this is to use the built in volume controller on the headphones.
lovesign wrote:Why would there be with dedicated volume keys ?! Get them fixed !The only other way to do this is to use the built in volume controller on the headphones.
No, they arent' working well, they are broken, i can only decrease volume, and i can't increase it!!! so any idea!!
Did you not read my post ?
Get them fixed or use the volume controller on the headphones.
