hi
can someone please send me the n73 barcode reader
its not on the nokia site or on download! on my phone
thanks
n73 barcode reader
Search on Catalogs application from phone.
The N73 version was recalled and removed from Catalogs due to certain instability issues. They hope to return it soon.
thats the problem i heard but then it has worked on some handsets
so could anyone host the file or give me a link
thanks
It was never released as a standalone .sis file, only via the Download! function within your N73.
Unless someone managed to extract it, you won't find it until it's re-released.
I've attached it for your delectation. A word of warning, though. When I first installed it, it wouldn't run, insisting that the component was already built in, or something.
Also, if it's been discontinued, then it is probably for a reason. Whether it's a good reason is another matter. The Nokia website is throwing up a lot of pictures of people shredding their ties and drawing on their faces at the moment, so I wouldn't trust them with anything important.
Finally, if that doesn't work, semacode reader does much the same job.
Regards
Tom
this thing cant read for shit, when taking a picture of a small barcode - the camera blurs! wtf! yeah fix it
May I ask for what are you using this app ?
naughtydude wrote:this thing cant read for shit, when taking a picture of a small barcode - the camera blurs! wtf! yeah fix it
Works fine for me on 1D and 2D codes.
