Streaming Audio/Video - Three Network
7 replies · 2,600 views · Started 24 February 2007
Has anybody had any success streaming audio or video content via the three network? I can stream content provided by Three, however, content from outside sources such as realplayer videos from the BBC website, simply timeout. Also live streaming ram files from the BBC timeout also. Streaming through my home access point works fine but 3G is a no go! Has anybody tried this or can anybody suggest any settings that might work? I'm guessing Three might be blocking such content to encourage you to download their own? Thanks in advance, Paul
Hi there,
I've got the same issue with 3 when using realplayer under 3G.
Not only that, I also cannot get slingplayer to work.
BR,
Felix.
I use InternetRadio to stream radio from the internet using 3. I also use LiveTV. Haven't tried streaming through Real Player though.
Dear dunarea,
will try internet radio tonight. Can you please check if your
realplayer works ?
BR,
Felix.
internet radio works with shoutcast.com, im not on 3 but my real player works pretty bad with online stream from orb:frown:, i would really like if they change real player to windows media player or winamp.
Hi SpeTz and dunarea,
Internet radio does not work with my n80 under 3 network.
However, orb works fine.
Any suggestion on how to get internet radio working ?
BR,
Felix.
try new pls from shoutcast.com, the playlist that comes with internet radio doesnt work for me either. Put the new .pls files in shoutcast in the memory card. Install both shoucast and internet radio sis files.
iczer3 wrote:Dear dunarea,
realplayer works ?
BR,
Felix.
I can confirm streaming with Real player on 3 network.
