i just have this problem in the last 2 or 3 days and i haven't installed anything during this time. when i slide open or closed my n80 ie the screen goes white for a bit, which can become even up to 4 5 seconds, before returning back to the normal screen. i deactivated and unistalled the keylock apps with no luck. anybody had this before?
thanks
the bottom half of my screen goes white for about 1-2 seconds where the 'keypad unlocked' signage goes...
For me is normal, if is a fast screen. Could be the video chip with some delay.
It happen to those early N80 most which upgraded to N80i and the keypad green call button also not reponding after a while. I took mine to Nokia care centre with N80i loaded and they did 2 changes and upgraded mine phone to N80i. Anybody care to explain the following parts# changes? 😊
1. 1MH Micro Dynamic Flex Interconnect Modul (9855185)
2. UI PWB Pad (9402628)
after trying a few hard reset and flashing, i took it to the nokia center in angel london and they found a bit of hardware (it's actually a strip of kind of cables) was damaged, probably by the sliding action and fixed it FREE, under warranty (no question asked.....)
THUMB UP for the guys in angel!!!!!
