Trouble connecting to PC
5 replies · 1,870 views · Started 02 March 2007
I try to connect my N70 to my PC and it doesn't seem to recognize it. The computer makes the sound that it makes when hardware is connected, but the computer PC Suite doesn't pick up that the phone is connected.
Any ideas? I can't put anything from the phone to computer or vice versa. I wana put music on my phone!
I had a similar problem in the past. Enter connections, uncheck and check again the USB cable.
well it's fixed. i wiped the disc and reinstalled PC suite and now its all working...
however, after i disconnected it from the computer, i didnt get any text messages from anyone for like a whole day which was odd...turns out my phone wasnt getting them. i had to restart my phone and it said i had 9 new meassages...anyone know what happened there? :con?
Maybe your phone froze. Have you tried to send an SMS or to call someone before restart?
yes. yes i have. i was able to send SMS and make phone calls, which is what made it confusing. and i could also recive calls, which made it even more confusing
This reminds me of the old 5110 which had so few options that it was impossible for the phone to freeze.
