Any way to get this other than going to a Service Center? It doesn't appear to be listed under the firmware thread but contains fixes relating to bluetooth standby supporting devices I believe?
i have the version 3.0705.0.31, and i like to come back to this version V3.0704.1.0.1, is it possible?
jawwiste wrote:i have the version 3.0705.0.31, and i like to come back to this version V3.0704.1.0.1, is it possible?
No.
any ways to get the original function for the Multimdeia key????????? 😞
Only by upgrading to a newer version of firmware that is not Music Edition.
Given that you have installed V3.0705.1.0.31 , there is currently no version higher than that. You are, as they say, screwed.
Until a newer IE, generic or other non ME version is released, that is.
i've just updated mine via the downloadable software NSU
And ?
What's your point ?
Are you mean that you uppdated your phone from the normal to music edition>>> and now you want to return to orginal edition> if yes you can
abdo krema wrote:Are you mean that you uppdated your phone from the normal to music edition>>> and now you want to return to orginal edition> if yes you can
No, you can't. The only way to restore the original version is to either use an expensive hardware device or wait until the non ME/IE firmware reaches a higher version than the one you have.
