I want to connect my dial up net on my N-Gage Classic through Bluetooth Device.Can anyone help me
Can anyone help me
now i'll tell u how i did mine. First of all, i installed the pc suite of a higher phone{3250 nokia} then i made a net connection on my laptop .GO THROUGH CONTROL PANEL-NET CONNECTIONS-CREATE NEW.select connect to internet-set it up manually-select dial up-bluthooth modem and bt fax modem-isp name{anything}-username/password{anything}then finish. After that, controlpanel-internet options -connections{choose the one created}-settings.check autodetect settings,use proxy server and bypass proxy server...then fill the blank spaces with data used to configure ur phone provided by the service provider..ie ur gateway IP address/proxy serv address=adress in pc and proxy port number{menu-toolo-connection-accesspoint-[service provider accesspoint]-options-advance settings}=port in pc. Use username and password from serviceprovider settings here {forget domain}..THIS IS FOR WINDOWS XP SP2. This settings is for GPRS connection and may not work 4 the main dialup.Note, may not work for pc's using external or artificial bluetooth.GOODLUCK
