Hi Guys,
Hope someone out there can help, this is driving me mad!
After doing some research I bought the CK-7W and CR-27, the phone fits the holder fine and charges via the pop-port which is what i wanted. But the car kit will not work via the pop-port only via bluetooth. Has anyone got the CK-7W and N73 working through the pop-port?
The problem is, if I connect the pop-port it disables the bluetooth so I cant charge it and use the bluetooth at the same time :frown: The only thing I can think of doing is disconnecting the wires in the holder and just leave the charge pins connected, that way I can leave the pop-port connected to charge the phone and then the CK-7W should allow the bluetooth to work?
I've tried upgrading the firmware to 3.0705.1.0.31 ME but it still does the same, although it has fixed loads of other faults!😊
Sorry for complicated description! Any help would be appreciated!
Rob
